K
Kootni
Hi members
Struggling to understand this GEFRAN pressure indicator wiring. Idea is to bypass this pressure indicator as it keeps cutting off supply to motor and stops the machine.
My question is on GEFRAN output1,2&3 what is C+ and NO avd how they do they work with relays etc
Pictures attached
So you wish to bypass a possibly safety critical device rather than diagnose the cause of the tripping?... do you have any reason to believe this unit is malfunctioning and not doing its job, if so then how will you achieve the same protection it provided once you disconnect it?... are you sure it is not doing what it is designed to do in the first place with either too high or low pressure dependent on what it is been used for.
This is a on a Machine just bought. We don’t use this device on other machines and it’s certainly not needed otherwise we would have kept it. Guy who had the machine before us kept it due to kind of raw material they used to run.
I would still heed caution, various models of similar machines may incorporate slightly different designs to eliminate the need for a device or utilise other forms of protective measures instead, as I don't know what these machines are and how they work I cannot advise further, I have seen ignorance kill in our industry so I hope you are going in with a full understanding of its function and the consequences of bypassing it - 'we don't use this device on other machines' gives me very little info' and does not say if it is still required on the model/brand you have.
As for your query, what is connected to the terminals to give me a better idea and what inputs are there, plus model no' of that unit, it is missing some letters or numbers, I could look it up then.
Asking such a basic question as what is C+ and NO suggests no knowledge of Controls circuits.
Not the basis for either fault finding or modifying circuits.
Get someone with knowledge to find the fault.
@dsrkwood thanks for your response.
No it’s not used on any other machihe at all. Never used and I have been in the industry fir a long time.
Basically from terminal 17 (wire333) shows 110V, terminal 16 (wire400) is 0. Terminal 15 (wire 394) goes to NC Stop and then onto NO start. Terminal 14 (wire 393) goes to a contactor T1 and then to motor terminal.
Please see attached unit picture
It always puzzles me why machine builders put devices on their machines that are not needed. If they didn't fit them they could save themselves loads of money, and either keep that as profit, or sell their machines cheaper and sell more of them, possibly even cheaper than their competition who do fit the devices that are not needed...
Sounds like it's a triac driven output I assume the stop circuit runs through the output Common and N/O terminals ... the gate will be a analogue input from the pressure sensor .... again guesswork from a distance given limited info ... dropping the 2 wires out and popping them in a connector will stop it interrupting the stop circuit from the pressure switch, what is the pressure measuring is it oil, coolant or anything like that if so you need to check the levels.
@darkwood it’s measuring plastic pressure in a barrel.
Also can you please go into bit more into details on Triac output (what it it?)and analogue gate? Very much appreciated
And yes stop circuit runs from Common.
Look up how a triac works if you don't understand it then I'll help out but in essence it can act like a relay but is more versatile and adaptable been part of electronics you can also cheaply adjust input thresholds ie sensitivity which you normally can't on a relay coil which has a fixed voltage value.
Analogue - is usually attributed to a variable value input like 0 - 10v or 4 - 20mA ( or inversed) ...the voltage or value represent a given measurement the device is detecting. You can also get digital input and these are done in 1's and 0's so 1 could represent on and zero off or a pulse train of thousands of counts per second to say measured the speed of a motor.
@darkwood ok will do
But can you pls explain the common and NO on this GEFRAN unit? Is it giving outputs voltage?
I'm guessing it just 'C' common in IE in your case stop in and N/O is the the default state of the output ... i assume the sensor has to give a signal to the input to allow the stop circuit to close at these terminal hence I questioned if it was measuring flow pressure, oil pressure Tec which would damage the machine if they dropped too low.
@darkwood so you mean C common is Neutral
And also does NO mean that no voltage coming out in default state?
Kootni,
Darkwood,
