Yeah, regardless of regs, bonding N+E in the plug especially doesn't feel right to me. It also leaves the possibility that another lead could be used in future that doesn't have the link.
At least linking the two inside the machine means that I can attach a big fat sticky label telling people that this is the case.
That looks much better and far more fit for purpose. You shouldn't have a problem bonding N+E on that one, I'd expect it to come with an option to do it as it's designed as home back-up.
Hopefully he can get a refund?
From Ebay or China?!
Certainly the one above seems a better bet, I assume the customer does not need three phase supply.
Does it say anything about the voltage stabilisation, I assume because it is designed as a backup generator it would be suitable but can't see anything on a quick glance, probably in the manual.
Yeah, it comes with AVR as standard. No need for TP supply.
The EVOPOWER set looks to be the far better bet, it'll probably have a far better AVR and other components than the £300 jobby too. No harm in asking this Generator supply company their recommendations as far as earthing provision to this set. I wouldn't mind betting that they too start talking about N-E connections at the plug top as well though!! Just don't have of it though. The earth connection on the control panel faceplate will be for touch/static voltage only.
What type of C/O switch are you going for, MTS or ATS?? Me i always recommend ATS, but it is the more expensive option. I suppose it depends on how simple you/customer wants the system to be and how accessible the system is going to be, once located in place etc...
The genny will be located in an outhouse about 15m away from the main property. I've only specced MTS as power cuts are very infrequent but when they do happen they happen for days.
it dont feel rite caus it aint rite...
what you will have created is a TN-C...not allowed in the UK...
Thinking about it, are we even doing that?? To do so would assume that a generator is the same as a DNO supply, which in every case will always have their star point referenced to earth. With this link removed it doesn't change the supply type does it, it just becomes dangerous. A generator provides an electrically seperate supply, linking the neutral to earth to not only reference to true ground but to provide a TN-S supply of sorts doesn't technically create a TN-C-S because the supply type doesn not conform with the norm anyway? That's my thinking. It still feels wrong though to bodge the N-E at the plug rather than in the genny.
Safety Information It looks like the manufacturer advocates a special "plug" that is connected to the changeover switch which is then plugged into genny. The plug has the NE link. This way they say means the genny can still have a floating earth for pure mobile use. Seams reasonable and sort of covers the issue of the genny being taken away or even sold on.
