Discharged
Here's the one (with a cable clamp):
Thank you. It might turn out that the stat is taller than I am anticipating and this would demand a correspondingly taller box - thus permitting the gland to be located in solid wall and not on a joint line.I'd use the strain relief grommets as shown on the Maplin site but NOT on a cut line in the casing / box unless no other option.
If you're using 1.5 T&E you'll need a large grommet as they work by putting a 'kink' in the cable within the body of the grommet so you get cable prtection and cable security.
Lofty.
The 'thermostat' you have shown is supposed to be mounted against the metal surface of a tank or cylinder etc and there's usually heat paste applied between the surfaces to improve the accuracy. I don't understand how you're going to mount this in a plastic enclosure. How is it going to work? What is it going to sense the temperature of if it's closed up in a box?Not in itself, no. It looks like this:![]()
You can see that it has two mounting holes, but if the casing does not allow, then I might have to find another way of securing it in there - No More Nails, for example. Again, if the casing permitted, then I might be able to fit a couple of cord grips.
Finally, to waterproof and protect the unit, I aim to fill it with potting compound/liquid rubber, from underneath where there will be room having cut a hole for the stat.
If the casing were cable-tied to the object it's there to monitor, would that be sufficient do you think, Marvo?The heat paste is optional, it depends on the application and how fast its response needs to be. This type of heat sensor usually mounts on two spot-welded threaded pins, 2 nuts keep it tensioned against the object it's sensing. If there's no mounting system already there then you're kinda in the twilight zone. It's going to be difficult to maintain the necessary tension.
