Aug 10, 2022
Petersfield
I have 2 outdoor floodlights & and pond pump. Each came fitted with H05RN-F cable.
I've looked at 4 cable suppliers' web sites. 2 of these say "suitable for temporary outdoor use", 1 says "suitable for permanent outdoor use" & 1 says nothing about indoor/outdoor use.
Does anyone have the specification or standard for HO5RN-F please? What does it say?
I don't have the spec to hand, but from memory...
H = harmonised
05 = OK up to 500V
R = rubber outer sheath.
N = neoprene inner sheath (i.e the insulation directly touching the copper conductor).
-F = flexible cable.
This is the cable that nearly always comes with pond pumps so it must be suitable for immersion in water.
I always use either RR or RN cable for use outdoors (as long as it's unlikely to get damaged, then you use SWA cable). RR means it has a rubber inner sheath as opposed to neoprene (although I think neoprene is a form of rubber).
Personally, I think VV cable (PVC rather than rubber) may be ok outdoors, as long as it is black, but I always use rubber as this is what I was taught.
H = harmonised
05 = OK up to 500V
Thanks for your reply. I think that the right cable for pond pumps is 3183P
What makes you suspicious that the cable may not be suitable?
He says he's seen a couple of websites that say it's only for temporary outdoor use.
Reactions: Marvo
Petersfield
H05RN-F cable spec
Electrical Tools and Products
DaveGr,
Marvo,
