The starting load of the transformer is 20w so replacing halogen with LED that is rated let’s say 5w won’t work as the minimum staring load is not met. In this case you would need a minimum of 4 LED’s connected to one transformer for them to work. I personally would change them to fire rated GU 10 LEDs connected to 230v supply
Important to distinguish between electronic 12V inverters and wound toroidal (or other) transformers. Electronic inverters can become unstable if the load is too small, so fitting a LED can result in flickering or premature failure of the inverter. Wound transformers typically shove out 12VAC or so regardless of load so work fine even running the lighter load of one or more LEDs.
Older 12V LEDs used to be a bit rubbish but newer ones have good light output and are a useful option to upgrade 12V halogens.
Thank you. Just to be sure I understood right, for someone with MR16 halogen bulbs as in the attached picture who wants to go LED, you'd recommend getting rid of the old transformer and installing a GU10 lamp holder? That seems much simpler than installing a driver for MR16 LED bulbs, indeed.
Bit of a thread resurrection but been doing a trade counter straw pole on this one and the findings are that no-one seems to know what the he'll I'm on about.
They just sell MR16 LED lamps, never had any back and don't recommend transformer replacement.
Now, the caveat is that your average trade counter staff is not always that knowledgeable but you'd expect they'd remember getting a slew of returns.
In my reactive maintenance role it doesn't really matter that the lamp might not last, typically it lasts longer than the staff, typically they last longer than the halogen they are replacing.
I can see why the domestic lot would rather replace for GU10s and it make sense.
It's largely personal preference, you can get good results using a 12V LED and a separate driver or using mains GU10. All LEDs are low voltage internally so in effect a GU10 is equivalent to an MR16 with an integrated driver.
The decision is usually made for convenience and aesthetics. It may be easier to swap out halogens with MR16 LEDs if you particularly like the light fitting, if they're hard to replace without damaging the decor or if the wiring is inaccessible.
Roger le Badger,
Shoei,
