S
sparkz
Done a re wire recently and went back to do the finals and fit few lights. The client wants me to fit 3 hand made lights just like the pic below. Im not too sure how to earth it, there is a earth terminal on the top fitment where you screw it onto the ceiling. Also theres no fix connection on the light fitting which could be againts the regs. I dont want to put a JB up in the ceiling and a bit flex hanging. Dont really know what to do....... appreciate your help.
If i un hook the fitting its not going to be earthed!
Excuse the poor pic. This is the top fitment. Its shaped as a bell and has hole in the middle where the flex comes through also theres not allot room for any terminal blocks.
Nothing wrong with using a connector block for the live cables.
Can you not leave the cpc long enough to connect with the top cowl down??
would it not depend on the type of lampholder used in the shade part of the fitting?
plastic double insulated? no earth required?
Looks like the fitting maybe metal.Can it not be earthed in the cowling part of the fitting where it will be all connected by the chain:confused:
