no swivel arm, just sits flat
go for 10 gauge 150mm screws then...brown plugs (7mm drill)...get `em in deep...right into the supstrate....just be careful when screwing them in though as you have a cavity behind the plasterboard...you dont want to be too keen with them screws and distort all the plaster...
Just doing the same thing at the moment - i have mounted the TV on the wall (excuse description here as not a DIY person) that is plasterboard with about 8-10cm of gap behind then a line of single brick then i assume the same on the other side to next door. I have mounted it on a stud and used a combination of normal plugs and those spring loaded plasterboard ones so its all secure. My big issue is also the power cable being in the wall - is it legal and also worried about the insulation material back there - is this not a fire risk? I am using part of an old flue for the cabling run as this was where an old fireplace used to be. Can someone advise me if the power cable should be ok as well as the HDMI?
