Hi,
I'm installing grid module/euro faceplates in my property from the Click Deco range. One of the components I want to put in a 4 module double faceplate is an HDMI port. I've looked at the Click Deco range and the internal connector is the same as the external faceplate - HDMI. I need the internal to be a terminal block to punch down the HDMI cable connections using a croning tool.
I was wondering if any of you more experienced folk might know whether other brands of modules are compatible with the Click Deco grid module faceplates and can recommend a terminal block back type module to suit?
Thanks so much for your help. It is most appreciated!
Best wishes,
Andrew
Best wishes,
Andrew
