Hi, quick question. I installed an Aico system among other things in a HMO 5 years ago. The kitchen is pretty standard size approx 5m by 5m. The Aico heat was installed not far from the doorway about a metre in due to the criss crossing nightmare joists. Now the client has had a HMO inspection and been told that the heat is in a bad position and should be moved closer to heat sources. Now I have never heard this before and wanted to run it by the forum and see if it is indeed a thing. I'm being a bit lazy but really cannot be arsed to trawl through building regs. Thanks in advance
