Discuss Heat mat programmable thermostat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi everyone wondering if any one can help point me indirection I have a heat mat installed with a ntc5k sensor and client is looking for a new programmable thermostat
most ones I found are ntc10k (warm up mat)I found a website where the manufacturer can adjust to suit floor sensor but can't rember where it was thanks
Heat mat do a programmable roomstat that you can set resistance of the floor probe.
Their technical team are pretty good and will talk through the process with you.
Or is it that the customer really doesnt like the heatmat programmers ?
Reply to Heat mat programmable thermostat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
Hi there I need your opinion on this one, I need to fix mat 18sqm (200w). Client instead of one mat bought 2 mats (12sqm)+(6sqm) one thermostat ...
I'm after some advice please, I have carbon mat underfloor heating throughout my bungalow, each room has its own thermostat and are fed via a...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
