K
Knobhead
What was he doing for it to short across his arm, that is the question?
Non, I’ve just fitted my new cooker, it’s GAS!
As i posted earlier...wouldn`t 90* thermosetting do it?.........What about the cable/flex to power the lights/ignition?![]()
No probs Archy mate......it is getting a bit silly with health n safety....as long as the cable is able to carry the current demand and is made off right and the run is appropriate.....i wouldn`t mind betting that the fault on cooker mentioned earlier on here was connected by diy charlie...i.e. wrong........and the circuit had no rcd additional protection..........Only joking Glenn, next they'll be saying a cooker will have to installed within a heat resistant cupboard! Utter nonsense.
I think it's a case of a bored 'designer tech' over specifying parts.
Guys becareful a tenant got a serve shock were we live his arm looked bad i wished i took a picture some one had installed a cooker and it shorted out across this guys arm not nice do not use TE for the final connection link use any thing but and check to make sure its RCD and its done all correctly some ones in trouble but dont let it be you..:cuss:
Went to wire up a new range cooker today and found that the manufacturers instructions call for a H05v2v2-f 6mm (PVC/PVC 90degree heat resisting) flexible cable.
Fine if that is what the manufacturer recomends, but where can you buy this in cut lenghts??.
You can also just use a black (tough) cable for exterior/catenary runs. We dont use pvc as it is effected by UV light (although i have seen it used outside with no protection on numerous occasions).....I use H07RN-F for wiring up cookers and ovens. I keep it in various csa's, all of which are rreadily available by the metre from Edmundsons (I tend to get 15m at a time). If you're really desperate Citys can get it by the metre too.
H07RN-F is also useful for a host of other situations too - recently did an external shower run in it using swa cleats to attach it to the wall.
Also great for running across catenary wires.
Always use end terminals on it though (cord end, ring, spade etc according to application)
