Discuss Heater/separate timer/ext cord/powerpoint in the DIY Electrical Advice area at ElectriciansForums.net
I
individual
Hi.
I have a new oil filled column heater (1000 Watts), which I would like to plug into a separate countdown timer (with a double pole switch. - Arlec 2 hour Countdown Timer.) Then plug the countdown timer into the socket end of a extension cord (1 metre length). And plug the other end of the extension cord into the bedroom powerpoint. (Or alternatively, plug the countdown timer into the powerpoint, plug the short extension cord into the timer, then plug the oil column heater into the socket end of the short extension cord.) But is it safe to do so?
  • A heater with a built in on/off timer is out of my budget, and some brands/models don't have good timer settings, functions or parts.
  • The 1 metre extension cord I have, can handle up to 10 Amps.
Reply to Heater/separate timer/ext cord/powerpoint in the DIY Electrical Advice area at ElectriciansForums.net
i am wiring up a new en-suite: it is about 1.7m square, shower cubicle in one corner, toilet in other, door between, basin next to shower. I will...
Hi there, I’ve hired a marquee for an event next month but am a bit lost on how to power it. There are 2 sockets 50 metres from the marquee and 2...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
I have an 80's oil-filled heater at home and although it's almost in mint condition on the outside, it's the heating element that's giving me...
Hiya, I live in a pretty old apartment in Japan. There's only one wall in the whole apartment that has a screw to allow to connect a power cable...
