Discuss Heatmiser UH3 troubleshooting in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi fellow electricians,
Wondering if anyone out there can kindly help me out? I have a underfloor heating controlled by UH3 heatmiser.
When thermostat control is activated, there is no boiler response and hence no heating.
Has anyone come across a similar problem? Is it a relay fault within the UH3 unit? Any other possible reasons for this (water pump?), etc. Any simple test to pinpoint fault?
Picture of indicator lights shown when zone heating is activated:
Thanks in advance!
Is this one of the remote thermostats? If so look at the instructions as it my be a case of just resetting the receiver to the channel in the control box. Sorry I can’t be more specific but I have a heatmeiser controller UF heating system and remember a similar issue.
Not remote. Wired thermostat. Which makes it even odder.
Hi,did you sort it? Would have asked how the boiler enable was wired,but you may have sussed it by now.
Reply to Heatmiser UH3 troubleshooting in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
