Discuss Help needed! in the Australia area at ElectriciansForums.net
S
SBlandford
Good afternoon guys.
My name is Scott Blandford and I'm writing this because I could use a hand, as I'm not that knowledgeable on matters to do with electrical work and the like. I'm currently writing an academic report for my course (Hospitality Management) and I have a couple of questions which I have no idea about and any help with them would be a huge help.
Regards
Scott
The questions are:
What colour should the outside sheathing of a PVC ring main cable be under new regulations?
Why does a TV have 3 amp cartridge fuses in its plug but an electric fan heater have a 13 amp fuse?
What would happen if you got them the wrong way around?
What should you do if an RCD covering the kitchen keeps tripping out on a busy Saturday night?
1. grey or white.
2. fuse is fitted to match the load ( amount of current drawn.
3. 3A would blow on the fan heater. 13A would not protect the tv flex in the event of a FAULT.
4. take her indoors out for a meal. call an electrician on sunday morning ( we love sunday work)
Cheers for the reply telectrix. On the fourth question, I meant what would you do if the RCD system kept tripping out in a commercial environment such as a restaurant kitchen? Although if it was at home I'm sure I'd take her for a curry to ease the pain :phone:
first, unplug all appliances. if that clears the fault, plug back in 1 at a time till you find the faulty appliance. if it does not clear, then all you can do is switch each breaker off and see if it's 1 particular circuit causing the tripping. then it's time to call a sparks.
There are no requirements for the colour of an outer sheath of a cable.
It can be any colour, as long as the conductors are correctly identified either by colour or by alpha numeric means.
I would question why a commercial kitchen has RCD protection.
It not a requirement of the Regulations, and to be honest, because of the damp atmosphere nuisance tripping should have been expected by the designer.
well you could always wire it out for a temp.......or if you wanted to be safer then just drop out the RCD and replace with a double pole incomer.....your choice of amperage rating of course......should hold anyway......
on the 4th question,find a good local spark sole trader or company give him all your electrical work without without question ie 3 quotes etc,that way when your kitchen goes down on a busy night he will be there quick as to get you back up,the cost of a nights lost business and the damage to your restaurants name will be small change to the bill from the spark.
Prior to 2004 PVC 6242Y (twin & earth) cable could be sheathed in grey or white. Since then PVC 6242YH* is sheathed grey. 6242BH (twin & earth) is sheathed white, but is made from cross linked polyethylene, which has a higher resistance to temperature and doesn't give off the same noxious fumes as PVC when burned, so fares better in the event of a fire and is generally preferred in commercial environments.
*The H stands for 'Harmonised' which refers to the 'new' colours, ie brown and blue rather than the 'old' red and black.
Give them that answer and they'll KNOW you cheated!
Reply to Help needed! in the Australia area at ElectriciansForums.net
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
https://www.walmart.com/ip/Minecraft-Green-Creeper-Body-12-Can-Mini-Fridge-8L-2-Door-Ambient-Lighting-25-2-H-9-5-W-9-1-D/2670909566 ok so let me...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
