steg22
I have been an apprentice for a few months. I was asked to change a light pull cord for a neighbour. When pulling down the pul cord i found a live in com and l1. There was no earth in the cables but there were two neutrals that were stripped about an inch and twisted together. Any reason why someone would do this? Is it being used as an earth?
Regards
Steg
Sounds like, 1 way light, feed to the switch, switched live out to the light, neutrals joined in switch!
With Lots of older properties you will find no CPC in the lighting circuits.
L in common. switched L in L1. the 2 blacks (blues) may be Neutrals. has the cpc been cut off?
Test it and find out.
WOW straight to the point.
Anyway, the wiring in the pull cord L into C, and L into L1 is fine, there may even be a L2, if it is a 2 way pull switch.
With pull switches on lighting circuits, it does matter which way round it is connected as long as one is in C and one is in either L1 or L2.
The lack of a CPC is not good, but you will need to advise the person that you are doing the work for, that they must under no circumstances fit any metal fittings to the circuit. But before you go in all gung-ho, have a close look at the wiring, it may have a CPC that you haven't seen.
The Neutrals have been twisted together because someone is lazy, and these need terminating into an insulated enclosure, use a small joint box.
Cheers………….Howard
Live Pair feeding the switch, apparently it's the done thing to make fitting John Lewis type luminairs
just done 1 like trhat with 1 of the super slim 4 port wagos. me and glenn got a handful or 3 from the freebie jar at elex.
10 large fistfulls dont you mean Tel...lol...
i kept going back in and dipping my shovel hands into that jar....
theres a knack to visits to the wago jar see...
what you do...is go there early...and grab a load...then you walk round for half an hour or so...hmm..time to go back...as they will have forgotten your face by then...and so another large fistful..
then you wait until theres a change of staff at the wago stall....go grab some more..
you can take the pis all day with a bit of planning....
yep. was like them crane grab machines you get in arcades, only with you, it was a prize every time. LOL. :50:
Cheers………….Howard
I kept writing..and deleting..and writing..and deleting. And gave up. Didnt like it.
If you are unsure...test and double check.
You are replacing like for like so can just put it back as it was...but neater. With a block/wago whatever.
Look at light see how thats wired.
Me...id get a feel for the place if its DIYee id want to test and be sure.
