Discuss Help Please! in the Australia area at ElectriciansForums.net
I have a practical exam on Thursday and have just found out I have to perform a test that I haven't yet covered(my own bloody fault)
So at this late hour I am getting a bit concerned.
I have a length of SWA 2.5mm 3 core wired into a CU at one end and an isolator at the other.
Could someone please explain simply to me how to perform 1,Continuity 2,Ins Resistance and 3,Polarity on the SWA
I have some idea but with a million thigs running through my head I need some help.
Thanks in advance
Gerry
Isolate cu
1)remove conductors from cu terminals
2) connect line to cpc of swa & test continuity at the load side of isolator between line & cpc, turn isolator on/off while testing prooves line is switched (R1+R2 done & polarity)
3) remove link between line & cpc
4) set meter to 500v test IR between line & cpc
5) test IR between neutral & cpc
6) test IR between neutral & cpc
Isolate cu
Thanks very much,very helpful
I see that steps 5 and 6 are the same,should step 5 be test IR between line and neutral.
Either way thanks again!
Reply to Help Please! in the Australia area at ElectriciansForums.net
Hi , I just started my designh project 2365 level 3 for hotel building. I have dyslexia I don’t know where to start can anymore done it before he...
Guidance please - C&G L3 electrical installation - Hotel extension project Hi folks, I am fairly new to this forum but it looks like the...
Good evening everyone Can any help or give me some advice please on measuring bending galv conduit. My question is bending long 3m lengths...
