M
mackthedaddy
Hi everyone, I have recently bought an alarm to fit on my motorcycle. what does the term " splitting the wire in half" mean? Obviously it doesn't mean cut it as it would just say cut, wouldn't it? Any help would be gratefully received! Cheers Paul
Sounds like a bad translation from the Chinese maybe? It must mean cut the wire - I can't think of any reason why you would do any different. Can you post a scan of the manual? Daz
No mate. I have a attachment on this reply showing diagram. It says I'll have a yellow or red wire going to my starter relay, then I have to half the wire and put pink wire on one side and brown wire on other?? You're localish! to me would you fit it? how much? Its a v2 cyclone alarm and Its going on a 1999 T reg Ninja.:omg_smile: Wont let me upload files at min:001_9898:
i would think it means to cut the existing red or yellow wire, and connect the pink to 1 and the brown to the other. just a guess though. don't take it as gospel.
You have to have 6 posts before you can attach a file. Just type in anything until you get your post count up.
Put the name into Google and check out some of the results. There are some biker forums mentioning the wiring of these. See which is best for you.
and when your engine cuts out at 70mph and you go over the crash barrier, there's always sorry mate, bikers turned lawyers.
99% certain it means cut the wire to the starter solenoid, and connect each of the alarm wires to each end of the cut wire. It will do the immobilising. You probably have enough posts to stick a picture on now. Daz
that's how i read it.
Still listening to Rock Radio Real XS then?
If you listen to Niamh Sweeney's rather difficult quiz, I get the occasional mention!
I worry when people say they do not understand an instruction to "cut the wire in the middle and attach the pink to one end and the brown to the other"...How flipping hard is that!!
hi Thanks for replies. In response to outspoken, I'm no sparky and with the terminology used I wanted to check. With it saying to split the wire in half I was thinking that I might have to cut it, then split both of the ends into 2 then join one back to original and the 2 new wires to the colours stated. Was seeing if this was normal sparky practice, hence the reason i'm asking sparkies for advice.There was no instruction to "cut the wire in the middle and attach the pink to one end and the brown to the other"...
Mack...sorry if this sounds insulting, do not mean it that way, but have you ever heard of common sense....what would splitting a cable along it's length achieve..Please, think about that!
