J
Justin2211
Hello people
i I need some help with motor connections I need to replace a tyre machine motor, I have the new motor but it's not quite the same I have a 4 pole 1hp motor cap/run/start the wiring on it shows how to wire in two opposite directions problem I have is you can only choose one or the other by moving links but I need both directions
its supplied from a foot peddle with a switch on push down for one direction up for the opposite with a separate lines for each
is there any way of making this work thanks
