B
bigonroad
I have a shed and summerhouse newly installed in the garden.
The shed is 10m from the house, the summerhouse around 35m.
I'll be laying a slab path from house, to shed, to summerhouse. Planning on laying cable underneath a) to protect it and b) so I know where it is.
Already had a spark wire up an exterior connector to the consumer unit, so would just connect to that.
Ideally want 2 double sockets in shed and 3 in Summer House. What are your thoughts on wiring, type of cable, etc.
Thanks,
C
what are you likely to have plugged into each building? It's likely that you'll be using armoured cable so that will need glading properly. I would suggest that maybe you get advice from your electrician and maybe run the cables yourself (donkey work) and get him to do the rest.
agree. ^^^^ . by all means dig the trench ( 2ft. deep ) get your electrician to calculate the load and size of cable required.
