Discuss HISPEC Mains-Rf Smoke detectors in the UK Electrical Forum area at ElectriciansForums.net
I've fitted a number of them and the only time I've had an issue is when I used them on a rewire and was going back to fit the heads (which I'd left wrapped up in a cupboard) after the rest of the building work was finished and the owner had decided to put them on without asking and had managed to break the test button on one and not locate the head properly on the other which caused it to overheat and fail (lesson learnt, I don't leave the heads on site now). They are basically a cheaper slightly less installer friendly copy of Aico, but (other than the above) I've not had any reports of them malfunctioning and they have the same length of warranty as Aico.
This is a review of the battery ones, though I suspect it would be similar for the mains ones:
Thanks for getting back to me
Damn, just put a few battery ones up in my house because we couldn't afford the wireless aico atm
Yes the Aico aint cheap, but if you fit battery Hispec ones in your own property then you can deal with any faults or issues yourself, however its a different story if you supply and fit them for a customer and you keep getting issues.
Reply to HISPEC Mains-Rf Smoke detectors in the UK Electrical Forum area at ElectriciansForums.net
Do Grade F1 smoke detectors with 10yr sealed battery and RF linking capability satisfy the BS 5839 -Part 6
Not sure what to do here. I am wiring detectors for someone, boiler is in a small cupboard in the bathroom. Too small to fit the detector as it...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Been covered before, but wondering if any amendments recently. I’ve been asked to fit detectors in a bungalow holiday cottage. Just over the...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
