dominicbatty
Hi,
I was wondering if it might be possible to pick someone's brains with regards to a new electricity supply. I am the treasurer of a community Hockey Club looking into the possibility of floodlighting our existing artificial pitch. It looks like we will need around 26 to 30 lamps at 2000w each requiring a maximum total of 60kw, we've also been told we need a 3 phase supply.
Our club already has a 3 phase supply but there are some concerns that
a) the club is over 200m from the artificial pitch, directly through our cricket pitches hence we'd like to avoid digging them up if we can
b) the cost of cable and of laying it those 200m is pretty expensive
c) we are not quite sure the club's existing supply can take this sort of additional load even if we got a cable installed.
So, we are thinking that given part of the pitch is only 20m from the nearest residential road, we might be able to get a new supply from SP Energy via the road supply directly to a cabinet pitch side, it might be a little more in cost but could save us a load of hassle.
Anyway, back to the point, I need to give SP Energy a KVA requirement for the 3 phase supply and I have absolutely no idea how to calculate it. It appears that if it is less than 70KVA we drop into a "cheaper" category. Would anyone be able to help me out with some calculations and if it's not too much to ask it would be really interesting to be able to understand the workings out but that's not a requirement, just for my own interest.
Many thanks, Dominic Batty.
The company that is quoting to do the work should do this , and if they are unable too i would suggest they are not up to a job of this size !
I see scouse will help you , but as i have said i think you would be best to look for a contractor that could do this simple task in the first place .
Lol scouse.... Don't u mean u want the job, the guy is in Liverpool & your scouse!
Hi guys, it's not a case of the electrical contractor either not being helpful or capable but its Sunday night and I was thinking if someone was online and it was a case of "a x b divided by c" then it would save me a little time. Many thx. Dom.
your final kva value will depend on the type of lights you use , but as just a ballpark figure , it will be around 65-75 , so theres no guarantee you will get the lower tariff.
however , i would still get a new elecy board supply from the nearest residential road even if its on a higher tariff as the digging costs and cable size will be massive for 200mtrs from the club house.
Dominic.
I think your comment regarding needing 26-30 lights at 2000w?? are you sure its 2000w? as you are treasurer maybe you should look at cost of running, and fit LED or Induction lighting which is more energy efficient and are low maintenance over a longer period the payback will benefit.
The contractor you use will be able to get a lighting scheme for you with the lux levels achieved and the total Kw required.
Hope this helps
Darren
Hi Darren, yes specs are correct we're talking about lighting a 100m x 50m area off 8 12 metre masts to give an average lux cover of 500 as that is what is required for hockey. As the treasurer I truly wish we could use led but at the moment my understanding is the technology/price is not available for this sort of job. We're looking at upwards of 60k for the project. Dom
It may work out cheaper to power the floodlights from a generator if the supply from the residential area won't take the load you need.
Hi biff, how did you get to 65-75 and why would it dependant on the light itself, are 2000w lamps different for some reason. Thx. Dom
