Discuss Home Automation in UK? in the UK Electrical Forum area at ElectriciansForums.net
In these areas: Alarms, CCTV, Security Systems, Satellite TV and Aerial Systems. also installed some systems Home automation, which are the marks and the protocol that uses here in the UK?
Only ever worked with CBus, Futronix...CBus is great and their DLT range are pure magic! Honeywells are great for incorporating into cBus! Had mine wired in oz where one key press turned on garage lights, opened the door and started the out door spa with mood lighting! CBus once learned is a doddle, unfortunately don't see in the UK much but is massive in Au, Saturn range being my favourite! Now just rambling on, so will end! :)
Reply to Home Automation in UK? in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
