Discuss * How many points? * in the UK Electrical Forum area at ElectriciansForums.net
A
Adam W
Following on from a discussion/argument/brouhaha at work today:
Would you describe a CCU (Cooker Control Unit) which incorporates a socket as 2 points since it does 2 different things, or 1 point since it's 1 accessory and 1 set of terminals?
Also would you count a cooker flex outlet as a point since it contains a set of terminals, or not since it's essentially a JB and not doing anything the terminals in the cooker don't do?
I wouldn't count the switch - only the cooker connection outlet. If the cooker switch has an integral socket outlet then I would call it a point additionally. As a point is defined as being for the connection of current-using equipment I would not count switches/isolators.
If a cooker control unit incorporates a socket outlet I call it 2 points ( the cooker point with socket and outlet below)
2 points of utilisation for current using equipment.
Is a double socket 2 points?
Is a light switch and Pendant 2 points?
I 2 way lighting and 1 Pendant 1,2 or 3 Points?
Whether for pricing or for test cert, there is some amount of different opinion on it.
Well done @Adam W - you've brought the ‘brouhaha’ to the forum!
I’m for CCU as a single point, even if it has a socket but I get @Ian1981s comment and thought - mmmmh I may be on the change!
Similar can be said of a double socket but although it incorporates 2 points of utilisation it’s still only ‘one point’ as in one double socket so I’d count a double socket as one.
If you had one cooker control switch but 2 outlets for say an oven and hob I count that as 2 , same reasoning as a control unit incorporating a socket outlet.
It’s trivial stuff really however you want to view it, this is just my opinion.
There are some good points (if you'll pardon the pun) being raised here. In the end my colleague wasn't having any of what I (and later on the boss when he popped in) were saying and called the NICEIC helpline...
Outcome from the helpline?
Can’t believe it got to that point tho!
No pun intended either :)
Although an isolator could be the point for connection of current using equipment ie 20amp DP switch feeding an immersion heater or a shower connected to shower isolator . Just out of interest would you count switches on a lighting circuit as points or just the pendants?
And if you wanted to be a complete A**E you could say that because the neon in the switch is connected and it is an item of current using equipment that anything with a neon is a point!!
Reply to * How many points? * in the UK Electrical Forum area at ElectriciansForums.net
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi I am seeking help and best practices to achieve below tasks. I am not across regulations hence will appreciate best approach to achieve below...
Have been asked to do remedials on an EICR that was carried out a year or so ago by another electrician. Curious to know what code you would give...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
