Discuss How to make transformer in the Electrical Tools and Products area at ElectriciansForums.net
Buy one.
If you look at the cost and time to buy the necessary tools, parts, and learn how to do it, and do it safely, you would have saved yourself a lot simply by buying a standard product.
Hello
How to make transformer for train 25000
Welcome to the forum mate.
I would assume that 2,500V transformers for trains are specially made.
Are you after making one or just knowing how they are manufactured?
First learn what it is, Then learn which type you wt, only then you might think of making one...
If you knoew enough about what you want, your question would be much more detailed
Reply to How to make transformer in the Electrical Tools and Products area at ElectriciansForums.net
Hello How to measure inductance of transformer
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
I installed a transformer for 5 smart thermostats, 1 of the thermostats trips the transformer fuse button right when I turn on the power. There is...
Hi, DIY’er here. I need a replacement transformer but can’t find the exact model required anywhere. It is Golden Power GP-SW120DC0700(UK)...
I’m building a vacuum exposure unit…..and so I’m sourcing a 24v transformer to match load of 24v timer…….timer will control qty 10 x 18 watt...
