I am interested in buying a medical device that says the max watt output is 5000 watts.
As far as I know you can only run up to 20 amp tops at home. I do NOT have a 220 or 240 volt outlet. Everything is 120 volt.
My questions are;
My questions are;
- I am pretty sure it is not going to work with my current setup let alone safe. Would a generator work for this purpose? I am only going to run this machine about 1-3 hrs a week
- Which generator do you recommend that can handle this much wattage?
- I have an option of getting either 120 volt US plug or a 220 EU plug. Would this choice make a difference and which one should I get?
- Any other options beside the generator? I am not really looking to do electrical work and install a 220 volt outlet
