L
Lewcius
Hello there. I'm studying for my level 3 2365 qual and struggling with some coursework. This particular question is: A trunking run within an electrical switchroom area is to contain the following single-core thermosetting stranded cables. 35x1.5mm2, 25x2.5mm2, 12x4.0mm2, 10x10mm2 and 5x16mm2. Determine the minimum size of trunking required to be used???? Is the answer as simple as making sure you can fit the 16mm2 cable in and you'll be fine???? Thanks in advance for taking the time.
