- Reaction score
- 60
Hi all, on a job and have three flats with immersion tanks in a separate boiler room. Immersion will be doing the hot water for the flats, I did run a 6.0mm to each of them as they are 15mtra away lucky I did as there are two immersion on each tank, just wondering the best way to wire it, I assume I can use a click cooker outlet that has two outlets in it but will a normal time switch for immersion be OK or is there a heftier one I'll need as I'm switching both immersions at the same time?
Cheers grand
Cheers grand
