G
Geordie Spark
Cheers !
While on subject, I was discussing with a colleague just the other day about bonding the boiler, seems a bit of a grey area, Whats your thoughts ? I usually bond flow/return.
Why do you do that??
Cheers !
Yeah thats correct...what confuses me is when doing my 17th the lecturer told us to bond the flow and return !
yes , just realised ...was first thing that came to mind![]()
Ive seen that done quite a few times to be honest but I know its creating different potentials.
They used to run backwards when you did that, but now they stop running so the reading doesn't reduce but it doesn't increase either ......... or so I've been told.
It's creating the potential to make you look ridiculous.
Then why didn't you question him??
Not as ridiculous as that car is that yours ?![]()
the gas lads like to see all the pipes crossbonded at the boiler....regardless of whether its needed...or not...
dont go there fella....
come back when you have the same level of knowledge as geordie will you...
so is it just the reading that stops....or the gas as well?
Ha Ha"Allegedly" the gas keeps flowing but the flow isn't recorded.
"someone"of my acquaintance who had business premises some years ago turned the meter around and left the heating on for the entire two weeks of the Christmas break knowing that the meter would run backwards.
Problem was when he returned from the Christmas break and put it back the right way round he found it had run back too far and the reading much lower than the previous bill which would have been difficult to explain, so he had to run the heating flat out get the reading increased a bit.
The labour force were sweating their wotsits off for the best part of a week.
was joke...
