Y
yamman35
went to a house today and it had a 3 phase 4 wire supply. The voltage across the phases is 400v but between the neutral and phases is 108v. The voltage in the property is 400v and has fried most of the appliances. Any ideas what had caused this, the client is a DIY disaster area and has been messing around in the consumer box.
Yeah, as gleen said - you've got a neutral loose/out somewhere. If it is floating, then chances are it could be live so it needs finding.
The answer to your question is in the very last sentence you wrote...the diy mong caused this.
Thanks for the quick response. The supply to the property now has affectively no neutral at the meter box. I know the client has been messing but what could he have done to cause this. Or could it be a fault with the supply and electric board as he claims. I was at the property the day before repairing cable damage on an AC unit caused by rats. The electric was fine then.
- - - Updated - - -
Something doesn’t ring true here. Is this you’re house? Are you the DIY disaster?
Sorry but if you’ve been carrying out repair work you should be able to do simple testing. No matter how voracious Spanish rats are, they won’t eat the neutral conductor. Even if it’s stripped bare it will still conduct.
Time to get the wallet out and pay an electrician in our euro subsidies.
I didn't say that the rats had eaten through the neutral, i said they had damaged air con unit. This isn't my house! Everything in the consumer unit seems fine and is a every professional installation, especially for spain. The client is in England and the neighbour with the key said he had the covers off prior to the problem. I just wanted to know what he could have done to cause this problem as it isn't obvious. No one else in the village is having supply problems.
you`v been told....check the neutral!!
