S
Sintra
Post: Fault finding series LED outside lighting (collingwood)
User: fall-apart-dave
Infraction: Inappropriate language
Administrative Note:
Message to User:
Swearing or trying to bypass the swear filter is not permitted on the open forums. Please refrain from using swear words as this would normally lead to a temporary ban but as you are a new member it is only an infraction this time.
Regards
Sintra.
Original Post:
Thinking about it I could enter light 5 and rewire it so the first 4/5 lights are connected with the rest disconnected and cut in half and in half again etc from there.
Bit of a pain though, downside of series wiring I suppose.
That works too, the reason I suggested running an extra cable is that would also tell you, if both ends lit up, that the fault was on the ground side. But yeah, swings & roundabouts. Series is a pain... F*ckin Christmas lights... Every b*stard year!!! Swapped to LED lights thinking "Yey! No more problems!!!" - WRONG! My LED ones were bloody series fed too, albeit grouned into a dozen or so parallel LEDs series fed.
