- Reaction score
- 0
Hi, I have just taken on a new job which involves 8 flats. I have been asked to install a intercom system for the flats. My questions are what is the best cable to use as I have read either cat5e or alarm cable are good options? Also a more open question is how are they wired briefly I assume from looking up its just one cat5e or alarm cable to each phone back to the main panel, one cable to the front door panel and a cable to the door lock all back to the main panel which is supplied by 240 to the transformer?! I'm sure I will be ok with connecting up as they are usually supplied with wiring diagrams. If anyone could help me with this would be greatly appreciated!
Also so can I add a extra door lock to a different door for one flat on the same system as thy have two entrances into one flat!
Thanks Rob
Thanks Rob
