Discuss Interesting for rcbo’s in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
From the code breakers book,which is a good buy,no mention of the 1667 ohm readings,my thinking if it don’t comply to the Zs measurements,then it don’t comply.
No more sticking a Rcd on that circuit,that’s if anybody does,to protect it .
Probably,it also means that,the high loops cannot be solved by just putting a rcbo in situ.
Even though this is contradicted in so many other topics on that subject.
Regs says 1667 ohms. So no code for high Zs because the regs says it’s ok with RCD protection?
Plenty of places around the country with high Zs readings have RCD protection to get round it. Just a thought at looking at it from the other direction, I could very well be wrong.
Question
Why is the earth fault loop so high
Answer
Who cares just stick an rcd on it
Not really a great diagnosis or solution imo
Because I’m on farmland and there’s nothing but rocks down below? ‍o_O
I’m not even sure why I’m following this thread or why I’m replying :tearsofjoy: maybe because I’m on holiday and the sun has finally gotten to me :tonguewink:
Reply to Interesting for rcbo’s in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a dual RCD board made by Hager installed a couple of months ago. It is high integrity, which I understand to mean RCBO’s can be...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
