A
ajelec10
Hi Guys, Haven't posted in a while,
Iam converting a colchester trimph 2000 metal lathe to single phase, as cost effective as possible, the internal wiring inside the machine is straight forward it has a main motor 5.5kw/7.5Hp and a suds pump both of these are dual voltage and iam looking at using a 203v single phase to 230v three phase inverter. There are some really cheap ones on eaby direct from China, has any one used these before? the
y have good feed back and a 12mth warranty allthough iam still not sure id much rather buy from reliable source but they are 5 times the price??? so iam wondering if i take a punt???
Whats your thoughts??
I also converted a Bridgeport mill to single phase so any questions welcome!
Buyer beware.
It's up to you, you could get a good one. If it was me then, no, I wouldn't buy.
Could you not use the same inverter for the miller?
Could you not use the same inverter for the miller?[/QUOTE
Cant use the one for the mill as the mill is only 2Hp and iam using a 3Hp drive also the drive needs to be hard wired dieter to motor. not a plug and play system
If they're 1/5th of the price I would already have alarm bells ringing. Find out the manufacturer and trawl the internet for genuine reviews on their quality. If you're unable to find the manufacturer or genuine good reviews then avoid them like the plague.
The thing is that with cheap gear that's of a decent or acceptable quality, somebody would already be importing it locally so you should find it from a locally based supplier as well as on-line.
You should be able to size the inverter for the biggest motor then program lower characteristics for a smaller motor. I have seen inverter used on multiple motors by using commando style plugs/socket. You also have to consider the control/e-stop etc. will have to be modified.
You could also buy used, loads on Ebay and the like. Some good makes too.
Its probably what i would do rather than buying a new chinese one of unknown quality.
Manuals are easy to download and just need the keypad for programming.
cheers
There are none on eBay, and only one from inverter drives, the problem is I require a 10hp single to three phase 230/230v inverter there are loads that do 3 phase to three phase but not many that do what I want? I can only find three options 1 Chinese one off eBay £250.00 delivered, one off inverter drives 4 week wait 550 + vat + delievery or one from drives direct. Good company great tec support and the inverter is 230v single phase input and 400v 3 phase out so no need to fiddle about with wiring too much! But it's 1300 delivered!! That's why I am asking if anyone has had any experience good or bad with the cheap ones I know it's gonna be poor quality but if it does the job am I won't be using the lahte too often, and some one has installed one with no issues then its worth a punt???
Not many single to three phase ones about they all seem to be three phase to three phase, so I guess no ones installed any?
What in the name of god needs 10HP? Rate the drive to the largest motor and use one at a time!
10HP works out at 33.21A 230 SP plus losses.
Get real!
Have fitted many variants 110 single to 220 3ph, 230v 1ph to 230v 3ph and often because im designing a control system and plc i often use recognised brands with uk based support centres, although your set up isnt as complicated i would quickly see loses with regards to time lost and machine down time if even a small compliction arose, as others have said alarm bells ring if it sounds too good to be true, also because yo are direct ordering from source the inverter may not comply within our market, its a big gamble i personally wouldn't entertain and even if it was functional for the year term - cheap internal electronics etc could see its overall lifespan vastly reduced.
I've never seen an inverter drive with single phase in and 3-phase out that can do 10hp duty. The largest drive of this nature I've ever come across was 3kW. Even finding one to run the 5.5kW main drive motor is going to be a tall order.
5.5kW is a large motor for a lathe, I've seen large lathes with a 5 meter bed that only use a 2-3kW motor, it might be worth investigating the power requirements and possible specifying a small motor if possible.
I was trained on a Colchester Triumph 2000 during my apprenticeship, I have fond memories of it :) Used a Bridgeport mill (think it was a 2J) as well :)
Would it not be cheaper and maybe easier to change the motor to say a 3hp? I would be surprised if you ever needed all the power that a 7.5ph would give.
Get real!
Well if you read the OP then its a trimpuh 2000 with a 7.5hp main motor and a small suds pump approx 1/4hp its then good practice to slightly oversize the inverter so its not at 100% duty so the next size up is a 10hp inerter drive. Thats Real!
John999uk Yes they are great machines iam only just starting to learn to use them (another string to the bow!) You are probably right we will never need the full power. I wanted my mate to get the student as its only 3hp but its something to do wit the 'up the spout size' as the trimpuh take 2" bar?? Also ive heard that the frame size is non standard and you run into problems with belt tension if you start messing around swapping out the motors??
Yes they are hard to find but they are out there, thats why iam struggling with this, if there was loads on the market it would prompt a little competition and hopefully bring the costs down! Inverter drives direct do a 230v input - 400v output rated at 20HP!!! its about 2.5K though!!
It looks like no ones taken a punt on the cheap Chinese ones then?, I may give it a go as i could buy 5 of them for the price of a normal one? even if they only last a year ill get 5 years LOL.!!!!
Thanks for alll your input Guys!!
AJ
