Discuss Ip ratings ip54/65. Which one? in the UK Electrical Forum area at ElectriciansForums.net
R
ryan24
hi.
Anyone able to explain why an adaptable box I bought says ip54/65 on it?
Just wondering which one actually is it? I'm guessing when I drill into it to put a coupler on it will it drop to ip54?
I guess as you say, if you don't make any holes in it and use it to bury your Hampster then IP65 but knocking a 20 or 25 in it and fitting a coupler or stuffing gland covers them in case your workmanship is lacking.
Unless of course it's just adaptable!
You have waaaayyy too much money.
Our last hamster got a freezer bag..... Not that we put him in the freezer or anything...... He went in the bin....
Hi. Going into it will be a 6mm swa and flex out to the heater. And a coupler connected to a ip rated fused spur for the pump. This is the one I
IP65 Adaptable Box 140 x 140 x 79mm - http://www.NoLinkingToThis/p/ip65-adaptable-box-140-x-140-x-79mm/13096
Hi - you know pools are a special electrical location? You will need an Electrician for this work and it will likely require building approval from your local authority, as it is a change to wiring in a special location. The good news is your friendly local Electrician can do that for you too.
Reply to Ip ratings ip54/65. Which one? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi All, Looking for a bit of advice. Just bought a boiling water tap, with a max kw rating of 1.5. We already have a waste disposal under the...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
