T
tony mc
If I was the landlord I would want a copy of the report not just the letting agencys say so.
At least Dick Turpin wore a mask!
Also, as far as I'm aware, plastic produces toxic fumes when burnt.
The NICEIC consider wooden Consumer Units a code 2, whereas plastic ones are considered acceptable.
Perhaps in the NICEIC world plastic doesn't burn?
When I was designing enclosures for electronic equipment, one of the criteria for selecting plastic material or parts was their flammability rating. If I remember right, UL94 V-0 was the spec for the most fire-resistant plastics; the plastic stops burning when you remove the source of heat.
As to toxic fumes, that's also possible to control, ie LSZH insulated cable.
More important are you insured to do PIR (EICR) reports.
If someone registered with NICEIC as a Domestic Installer but not registered under “Electrical Condition Inspection Report (ECIR)” scheme, in theory he should not be doing a PIR. Is this right or wrong? But the reg. stipulated that PIR should be done by a competent person. I have seen survey reports from Estate Agents that said "Condition of electrical installation should be checked and a report obtained from a NICEIC Electrical Contractor." There was nothing that said that Electrical Contractor must be registered under “Electrical Condition Inspection Report (ECIR)” scheme. I am sure this topic was discussed time & time again, please, pardon me:banghead:
If the guy is domestic installer hes proved to be competent cause hes registered deffinately legal
