S
...maybe go with a C-curve mcb if your impedance is low enough to still achieve disconnect times or is it the plug fuses that are popping?.Very nice...maybe go with a C-curve mcb if your impedance is low enough to still achieve disconnect times or is it the plug fuses that are popping?.
Got them on a plug top at the moment. Can get a couple arcs then the 13 amp 1362 fails. :shades_smile:
Lol, I forgot you have 13A socket outlets in the UK, I'm used to the 16A sockets we have here. If you carry on expanding your system you're going to have to install a shower circuit with a 32A commando socket for your experiments![]()
