Discuss Jointing 5 core SWA in the Electrical Tools and Products area at ElectriciansForums.net
jeremy
Mentor
Does anyone know offhand where I can source a 5 core 25mm SWA joint kit from?
Designer worked out run length from drawings and assumed no ups downs etc. He was only 45m out!! Unfortunately we've already pulled in the 100m supplied and need to extend. Any help greatly appreciated as the solution so far suggested (by designer) is use a 4 core joint and use an extra connector. I don't like it but if it's the only way, then so be it. Thanks in advance.
above or below ground for the joint???
45% out! must be some long up and downs for him to be that far out. dock his biscuits at play time
In a duct . I'm guessing that they'll want a completely sealed(resin?) joint. I've only ever used 4core ones and can't readily see any greater than that on web. He deserves NO biscuits ever!!
Had to do a 5c 25mm joint about a year ago. i used a resin jointing kit for a 4 core 35mm and had plenty of room to crimp and sleeve the 5 25mm conductors plus the earth strap.
that's the prob with going by drawings. i prefer to pace it out. as i only got short legs, i work in yards, then add 20% for error, plus when it's in metres i get an extra 10%. anything left over goes in my scrap box
Reply to Jointing 5 core SWA in the Electrical Tools and Products area at ElectriciansForums.net
Hi, we need to joint several 95mm² 4 core SWA cables, the joints kit are Prysmian JST Low Voltage Universal Cable Joints and are supplied with...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
So, the actual job is on a farm. I think I'll keep things simple at the moment and just ask about voltage drop. I'll come on to earthing and...
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
