baza890
Trainee
can u connect a 1.5mm with a 1.0mm in a jb i assume u can but it is bigger which is making these connections alot harder and fidgety. is it better to get a maintenance free junction box from screwfix and can all the wires fit into the jb, its four wires 1.0mm or 3 wires 1mm and one 1.5m?
(and no i didnt wire i just brought them down from the joists) and if someone can can you link the JB from screwfix if not all good
No problem with one designed for four cables!
Available from many outlets, but not Screwfix for some reason!
There are other options, but I've used these successfully.
Buy some earth sleeving whilst you're there.
baza890
Trainee
birmingham
United Kingdom
Trainee Electrician
junction box help
Talk Electrician Forum
Thread Tags
Tags Tags
help
baza890,
mainline,
