M
melvinmoo
good morning all I have to fit a 37 kw industrial 3 phase oven this pulls 51 amps . I can only find an old 60amp three pole c50 Crabtree breaker to fit the old board that exists I will fit a 63 amp four pole rcd after this will this be ok thanks for your help
The crabtree breaker will ok, but I wouldn't fit a RCD to a oven circuit as ovens have high earth leakage
thanks phil I will double check with the manufacturer has told me it needed a 63 amp rcd
