Discuss Kitchen Rewiring in the DIY Electrical Advice area at ElectriciansForums.net
stacer
F75BF702-7C91-4985-B43A-2BA8581B02D4.jpegThe wiring and metal socket boxes for my new kitchen are now covered by plasterboard, how will the electrician find them to wire them
Hopefully he measured from the side wall and the floor before it got covered... so all he has to do is measure them out again and poke a hole through the board.
A question could be asked about his cable route in prescribed zones... What are other members thoughts on this?
Unfortunately, the plasterboard has been skimmed with plaster, so I reckon cutting a hole will make a mess of that. Should the holes have cut before?
Itll be fine.
Its an everyday occurrence for domestic sparks where we have to cut out a hole. A sharp jab saw will soon cut through.
Its easier for the plasterer to skim where there's a flat surface... precut holes make it difficult for them.
I presume this is for a utility room? Would you be tiling or perhaps a splashback of wetwall?
Itll be fine.
Thanks for that, you put my mind at ease. This corner of the kitchen will have an under counter freestanding washing machine on the left with a sink base unit to the right. There will be some tiling done above the work top when the kitchen is complete.
Reply to Kitchen Rewiring in the DIY Electrical Advice area at ElectriciansForums.net
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
