J
John tomo 1972
can anyone correct me if I’m wrong. If it’s a rented accommodation do the smoke detectors/monoxide need to be hard wired in relation to EICRs as I’ve just had a lanlawd tell me to stop talking sh@t
AFAIK, the regulations for fire detection in rented accommodation can be either 230v or 10 year lithium battery powered ( battery cannot be removed)
The only stipulation is that they are interlinked. Hard wired or via radio link.
Best place to ask would be a local letting agency.
I do a lot of work for a local letting agency, frankly it's the last place I'd ask. I'd be surprised if any of them have any sort of an idea about what should be installed and what products are available.
Rental properties in Scotland require mains-operated, interlinked smoke and heat alarms. The alarms must have a battery back-up. It doesn't matter whether the battery is a built-in lithium or a removable 9V. CO detectors are also required for rooms containing a gas appliance or flue, but need not be mains-operated or interlinked.
With regards to EICRs, if battery/230 volt smoke alarms are present, I'll do a push test to see if they function. If not, I'll give the homeowner a heads-up. If the alarms are mains-operated, I always test the circuit and record the test results on the report.
Are you sure, JK? I thought, as long as they were interlinked, it could be mains or lithium battery?
Below is section 8 of the Scottish Government's Fire detection in private rented properties: guidance .....
When the Repairing Standard was introduced (3 September 2007) the building standards regulations required that there should be one or more than one functioning smoke alarm installed in the house, the number and position of alarms to be determined by the size and layout of the house. There was normally to be at least one smoke alarm on each floor. If there were multiple alarms, they should be interlinked. A smoke alarm installed from 3 September 2007 onwards had to be mains powered with a standby power supply. Note that the manufacturer’s recommended life span of a fire alarm is usually 5-10 years and all battery-powered fire alarms in private rented houses should hardwired when they are replaced.
