K
kevyn
It is rife in sw Scotland. In my old job we rewired 5 houses in the same street one after the other. All lead no vir or anything else. There will still be some houses with lead aswell
I am going to a job this morning which has lead sheathed cable and cotton cloth covered wires. It also has a new 17th edition CU. I thought with wiring this old it should be condemned and replaced. It might be 60 to 100 years old. Am I to assume if it is working fine and testing fine it should be left?
It is in an old tenement in Glasgow with beautiful plaster cornices and ceiling roses. The customer bought the flat two months ago and if it is to be rewired ( lighting only) the mess will be horrendous for them.
I would assume that whoever installed the CU would have left a test cert. but somehow I doubt it, as I think the new board was simply to make things look ok for selling.
There is no requirement under building regs in Scotland to do anything about 100 year old cables. What was said to me was to look in the IEE regs. The wiring does not conform to the 17th edition regs as cables have been run on top of door frames on the surface and are located within door frames as are some switches. The insulation in the some of the switches is frayed.
However if 100 year old cables conformed to 17th edition wiring regs and tested fine, would it really be ok just to leave them?
In this case they do not conform. I was posing a hypothetical question. I think if it were me and the cables complied while testing within the parameters of the IEE regs I would leave them.Your the electrician, ...it's your call, and the householder's of course!!
