A
adsumore
Hi I wonder if someone can comment on the following ?
Connected a gas hob to a socket in the kitchen, tested the spark was fine...then pushed the kettle on and the consumer unit tripped. Then I couldnt get the unit to stay on until I unplugged the hob completely ? The hob wasnt drawing any power when the kettle was turned on (and the kettle is fine) the hob is only using power for the spark. Also on the same ring I have a dab radio, which if you touch the ariel you can feel a slight tingle. Help ?
agree. sounds like an earth or bonding problem.
