Discuss leccy question in the Industrial Electricians' Talk area at ElectriciansForums.net
N
newspark2
Hi, Iam a gas eng with a tech question.
A boiler fan resistance measures 44ohms, connected to a 230v supply. What current will it pull from the mains.
TIA.
5.2A,but sounds a bit high,what kind of boiler is it domestic/industrial? check plate on fan motor for FLC(full load current cheers
TIA.
well theoretically it would be 5 amps, but you are talking about resistance - does that mean you have measured with a meter?
problem is you see, that is 'cold' DC resistance; when power is applied, we talk about impedence, which is a different ball game. Without getting into a technical lesson, there such factors as BackEMF, mutual induction,hysteris losses,inductive reactance etc etc that affect the (ac)'resistance' or impedence. This why on an ac component, the resistance is rarely given, its rating (in Watts) is given, as this is a product of impedence anyway.
Are you sure the fan's connected to the mains? I would have thought the fan, along with the gas valve and such would be controlled from the circuit board which is usually in the 24V region.
Reply to leccy question in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hi, I thought to make a post, I came just to ask questions but been reading more of the forum and learnt lots of useful and good things, decided I...
