Discuss Lifting glued T&G chipboard in the UK Electrical Forum area at ElectriciansForums.net
As mentioned above NEVER cut along the tongue as if it is glued down it will just disintegrate when you try to rip it up
The last re-wire I did with weetabix floors , I cut a rectangle hole between the joists with a multi-tool and then used some off cuts of 4x2 and screwed to the sides of the joists and then put the bit back in the hole or cut a new out of some 22mm ply board.
Took blooming ages this way but no damages to the ceilings and once the carpets went back you would never know I had been.
The cost of wood for that today is expensive. T&G is about £15 a sheet.
Proper re-claimed floor boards are crazy expensive , you think they used to go in the skip now they go straight on Ebay along with any pulled out white red black cable that gets measured coiled up ad listed straight on Ebay.
I am getting well over £1 per mtr for red black twin n earth
my solution is get a chippie to do it. then if there's any problems, it's his fault, not yours.
I have tried getting a chippie in for pre rewire prep to get flooring up and they aren't interested , they all say its too much agro and not worth the headache
I’ve used the drill kits with the plastic laid in plugs before.
About 8 plugs in one house across two bedrooms.
They just lie in loose on a rebated edge. Not fixed… so luckily most of the holes ended up inside a built in wardrobe, or under furniture… not getting walked on.
Some provide plastic plugs, whereas others have steel plates to bond into place. Often wondered which (if either) was the better option.
Why are they buying this? For nostalgia or weigh in?
I really don't know , and I honestly don't care
Some bloke paid me nearly £100 the other day for 40mtrs of 4mm red/black T&e that I pulled out of a job
The mind boggles as he could easily go to Screwfix and get a 50mtr drum for less
Reply to Lifting glued T&G chipboard in the UK Electrical Forum area at ElectriciansForums.net
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
  • Locked
5K
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
