Discuss Lighting backfeed in the DIY Electrical Advice area at ElectriciansForums.net
Those three swtches control 4 total lights on one cuircut
@Jchandler1965 I went back and read your profile and it appears to be a great job you did but since it’s on it’s own circuit and you have all your neutrals wired together right and you are breaking only the hots through the light switches. One question after watching your video it makes me think are them type of switches you are using LED compatible. In my mind your installation looks good so we can’t see the actual wiring it has to be them push switches can leak voltage and make your lights do some funky things. Every thing we have discussed it has to be the switches, I’ve seen worse and LED lighting and plain old switches just don’t work right. Replace the switches with LED compatible switches. Good luck
Thank you for your assistance.
What are the LED compatible switches and how do they differ from normal ones? Do they have components in them to counter any inductive or capacitive pickup?
@DPG when LED lighting first come out people started having trouble with their lights. Now they make switches for LED lighting but people go out and buy just any old switch without a thought of their lighting. It has to be the switches, DPG we’ve worked our minds hard over this. The regular switch can leak voltage at maybe 20-30vac and if that’s not it I don’t know what to tell him
[automerge]1573833454[/automerge]
The contacts on regular switches don’t open far enough which leads to leaking. I don’t know if you have ever worked on the old Allen Bradley PLC s and on digital outputs there contacts are called triacs which would leak 50vac so I guess I’m trying to tell you that regular switches act like triacs
I don't believe the contacts on a mains light switch don't open enough to fully break the circuit.
Obviously I get the theory of triacs and electronic switching and dimming, but we are talking straight on/off switches here
DPG if the switches don’t work I don’t know what else to tell him. If all the neutrals are wired correctly and the grounds made up I just don’t see another way that this problem could happen
Reply to Lighting backfeed in the DIY Electrical Advice area at ElectriciansForums.net
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
Legends, need some advice. I am a 12v automotive electrician, but have had a side project building a concession trailer for my dad. We have an...
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
