Discuss List of acronyms in the ElectriciansForums.net News and Updates area at ElectriciansForums.net
Markie, looks like you missed out CU, and used CCU instead, EEBAD should be EEBADS, Ra should resistance of earth electrode only.
Then there's just a couple you missed:
ADS: Automatic Disconnection of Supply,
AWA: Aluminium Wired Armour,
CT: Current Transformer,
DB: Distribution Board,
EFLI: Earth Fault Loop Impedance,
ELV: Extra Low Voltage,
EMT: Earth Marshaling Terminal,
ESQCR: Electricity Safety, Quality and Continuity Regulations,
IET: Institute of Engineering and Technology,
FELV: Functional Extra Low Voltage,
HV: High Voltage,
LSC: Luminair Supporting Coupler,
LV: Low Voltage,
MEN: Multiple Earth Neutral connection (used abroad to describe PME),
MET: Main Earth Terminal,
MV: Medium Voltage (not used in this country anymore),
PBC: Protective Bonding Conductor,
PE: Protective Earthing,
PEFC: Prospective Earth Fault,
PFC: Prospective Fault Current,
PME: Protective Multiple Earthing,
PNB: Protective Neutral Bonding,
PSCC: Prospective Short Circuit Current,
PV: Pholtaic Voltage (solar power),
R1: Resistance of line conductor,
R2: Resistance of earth conductor,
r1: resistance of line conductor (taken at socket-outlets on RFC),
r2: resistance of earth conductor (taken at socket-outlets on RFC),
rn: resistance of neutral conductor (taken at socket-outlets on RFC), RFC: Ring Final Circuit,
SFCU: Switched Fused Connection Unit, SNE: Separate Neutral and Earth (cable), So: Socket-outlet,
SRCD: Socket-outlet incorporating an RCD, IT: Information Technology, IT: Impedance Earthing (Terra),
TN: Terra Neutral, TN-C:
Terra Neutral Combined,
TN-S: Terra Neutral Separated,
TN-C-S: Terra Neutral Combined then Separated,
TT: Terra Terra,
Tx: Transformer,
Zdb: Zs at DB.
What about NORWICH kNickers Off Ready When I Come Home.
And my favourite from my Airline days. BOEING
Bits Of Engine In Neighbours Gardens
Cheers............Howard
Reply to List of acronyms in the ElectriciansForums.net News and Updates area at ElectriciansForums.net
I disassembled a Christmas light projector to try and identify the cause of why the images from the projector weren't moving at all, when they...
Hi, as the title says, I need to change the upper heating element on my HE10AB220/C oven. I've never done that and it seems pretty easy, as in...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Good morning, We have a two-bedroom flat that my wife and I rent out to supplement our income. Following the recent EICR, several issues...
