T
tom262
hello all,i am currently doing some workin some offices and have been asked to change a faulty heater, the problem i have is they want a heater/aircon in one, ive heard about pipeless aircons/heaters and the owner believes he has also seen them but i cant find them anywhere!!!! any help would be much appricated
(must not have any piping or rad as is a listed property)
thank you
As said above,closest thing i can think of is portable, think even Argos do them! Think you can get more commercial ones though, dont think there is such thing as air con with no pipwork, even the portable ones need a window to put the duct out to get rid of hot/cold air.
"Hello Tom262",
There are portable Air Conditioning / Heater units available - BUT:
Even a portable Air Conditioner / Heater has to discharge the warm Air to outside when in A/C mode - via usually a 100mm or 150mm Flexible Pipe.
You will not be able to operate an Air Conditioning Unit without discharging the warm air to outside.
IF there are Sash Windows at the premises for Temporary / Summer use You could make up a Board / Draught proof strip etc to enable the A/C Flexible Pipe to discharge through a hole in the Board with the Window closing down onto the Board - and pieces of Pipe Insulation `sealing` the gap above between the top of the Lower half of the Sash Window and the Glass of the Upper half of the Window.
This is hard to explain even though I have done this in the past for a couple of Rooms at my Home for Temporary / Summer use of portable Air Conditioning Units.
Good Luck in finding a solution / suitable product / or being able to Tempoarily fit a Window Board etc. to connect a portable Air Conditioner / Heater discharge pipe.
Regards,
Chris
Try TLC electrical supplies and search for a portable air conditioner"
Can't link.the forum won't allow it
Is there anything else I can use that isn't portable and heats in winter and cools in summer?? Thank you
Can always install a wall banger AC, but then you need to make an opening in the wall for the unit to fit into, as well as the problem of weatherproof sealing it in!! So in other words NO mate!! You're basically stuck with wall/ceiling or floor mounted split AC's that will require two copper pipes and a cable through the wall to connect the external condensing unit with the indoor FCU!!
What ****ter!! No problem cheers for the help!!
Being a non verbal obscenity type of guy,I can't seem to work out the missing letters
Can someone please oblige?
I'll presume its nothing to do with the English city Scun Thorpe
