Hi Guys,
I have a looped service in my house, concerned about the cable going next door. It looks old and brittle (I have not touched) . It was installed about 1955, do you think SP Energy Networks would replace the cable
The conduit containing those wires must be earthed, and well enough to deal with a really big fault. No idea if it is earthed somewhere out of sight though.
The other issue is they are almost certainly VIR (vulcanised Indian rubber) insulated wires. In most cases the rubber perishes and becomes brittle so dangerous if anything causes movement. They might be OK, miracles do happen, but you have the right attitude of not touching them at all.
The results of a short anywhere exposed to you has the very real risk of 3rd degree burns from the arc-flash and possible eyesight damage, not to mention a house fire risk and electric shock.
Hi thanks I have sent them a message and photo of it. However I wanted some advice from you guys in case the try to say it's ok.
If they say it is ok there is little you can do other than make a note of the contact with them for future reference, I had something similar a few years ago, I'm surprised they didn't swap the cable when they changed the service head
Hi thanks no earth at my end there was but was cut of when they changed the service head. Just had the faulty meter changed (that's another story!) guy said he would also mention the old cables in his report.
Scotland
United Kingdom
Looped Service
UK
Mrtilly,
Mrtilly,
