Discuss Low Amperage From 4-100w Renogy Panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
dnpowers
Hello all. I had 4 renogy 100w panels running to a 30amp renogy charge controller. I started noticing a low battery situation so I started doing some tests. If I completely disconnect the panels from the system and check each panel individually I get between 19.5-20.5v on all 4 panels, but I am only seeing .18, .19, .21 & .31 amp from each panel. I ran my multimeter in line on both the + and - wires as well as introduced a load on the circuit with the same low amperage results. What happened or what am I doing wrong? Thanks for your help!
You will only get close to the full rated power when the sun is at 1000 watts per square meter , this assumes no shading, on the back of the panel you should see an open circuit voltage and a short circuit current.
Reply to Low Amperage From 4-100w Renogy Panels in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I have a sub panel about 75ft from my house attached to my shed that feeds a pool pump, some outlets and a pool heater which is no longer used...
Good morning all. Before I start I am not an electrician and am relatively new to this topic. Current set up Axpert 5.5 Kw inverter, 7 x 420...
I am trying to understand the amperage flow in my 200 amp main panel. In theory, (example only), let's say you had a 200 main panel installed...
